URL Handler
Home Assistant supports opening from other apps via URL.
Platform compatibility​
Platform support of different types of deeplinks will vary, consult the table below to see which deeplink types are available for your platform.
Deeplink typeAndroid AndroidiOS & macOS
Navigate✅✅
Call service✅
Fire event✅
Send location✅
This allows you to update the frontend page location via a deeplink. To build a deeplink, follow these steps:
  1. Navigate to the link you'd like to deeplink to in the web app, e.g. http://homeassistant.local:8123/dashboard-mobile/my-subview
  2. Copy the path portion of the URL, in this example that would be /dashboard-mobile/my-subview
  3. Craft your URL by starting with homeassistant://navigate and adding the path, e.g. homeassistant://navigate/dashboard-mobile/my-subview
info
By default the App will ask which server you want to navigate to in case you have multiple servers. To define which server you want to navigate to, use the query param ?server= like the example below:
homeassistant://navigate/webcams?server=My%20home when your server name is My Home, or use ?server=default if you want to navigate to the first server available.
Call service​
Example: homeassistant://call_service/device_tracker.see?entity_id=device_tracker.entity
Query parameters are passed as a dictionary in the call.
info
If multiple servers are connected to an app, call_service links will be handled using the first server in the list.
Fire event​
You can create an event trigger and fire the event.
Example: homeassistant://fire_event/custom_event?entity_id=MY_CUSTOM_EVENT
info
If multiple servers are connected to an app, fire_event links will be handled using the first server in the list.
Send location​
Example: homeassistant://send_location/
