Android Quick Settings
The Android app offers support for quick settings tiles allowing you to quickly execute a script/scene, press (input) buttons or toggle supported domains from the notification pull down menu. You can fully customize the appearance of these tile and can reorganize them as you see fit. This feature is available on devices running Android 7.0+. To get started navigate to Settings > Companion App > Manage Tiles.
The app currently offers up to 40 tiles to setup. Each tile must have a label set and on Android 10 or newer can optionally have a sublabel set. After a label and entity have been selected you will be able to update the tile data. Once updated, the tile is ready to be used: edit your device's quick settings panel and drag the Home Assistant tile from the list of tiles into the active section.
Once a tile has been added, the state, label and icon will update to reflect the entity's state and tile settings. When you select a tile you will see the tile momentarily light up as the app calls the server. If successfull the tile will go back to show the entity's state, if there is a failure the tile changes to a disabled state and an error message will be shown.
The following domains are supported:
automation
Togglebutton
Presscover
Togglefan
Togglehumidifier
Toggleinput_boolean
Toggleinput_button
Presslight
Togglelock
Lock/Unlockmedia_player
Toggleremote
Togglesiren
Togglescene
Turn on scenescript
Turn on scriptswitch
Toggle
Optional additional settings:
- Tiles will use the entity icon by default. Tap on the icon to use a different icon for the tile.
- Vibrate when clicked can be enabled to vibrate once when the tile is clicked and twice if the action fails.
- Requires unlocked device can be enabled to only allow interacting with the tile if the device is unlocked.
